OMC / Mercruiser Interchangable?
cgrooves
What is the difference between a 15 tooth, 4.5" hub OMC prop that does not allow you to use it on a 15 tooth, 4.5" Mercruiser outdrive?
Thanks.
gcboat
Re: OMC / Mercruiser Interchangable?
Don't shoot me if I'm wrong but I believe it is the thickness of the splines.
Nope,... It's the Length of the Splines.....
I forget which way it works,...
But,...
I believe you can put a Merc prop on an OMC, but Not the other way around.....
Or,...
Maybe that's backwards...
walleyehed
The OMC props Will work on Mercruiser, but use the OMC thrustwasher.
Merc props use a 3/4" longer spline.
OMC will work on Merc, but not the other way around...the proper thrustwasher must be used as well.
I have reamed Merc props at 13/16" to work on OMC, but the equipment to do it right is a must.
