Boilermaker
- Sep 28, 2003
- 388
I need a new prop for my 18ft Deep Modified Vee with Johnson 115 (fresh 1978 model>>PLEASE see my post "NEWGUY PROP???") The engine ORIGINALLY had a 13x19 and ran well>>>but that was the old "elephant ear" style OMC with no cupping>>now that prop needs a new hub, and I don't think its worth the cost.<br />I tried a new 14x19, and had a slow holeshot when loaded, But loved the topspeed>>even at 4800rpm.<br /><br />I am now running a "newstyle" 14x17 Alum OMC prop (shop loaner) and seeing 5300RPM with good throttle responce.<br /> I would like to step up to a STAINLESS prop but don't know if I should stick with the OMC, or would be better off with an aftermarket prop??? IF an OMC>>>Which style (I see on the web page they have a few different styles S.S.)???>>If aftermarket>>>should I get a VENTED hub or not???<br />I see a few aftermarket props that are 13x19 or 13.5 x19 ect...>>>would that be closer to the original in terms of holeshot and still have good topend??? How are the props that have seperate hubs and blade castings??? Seems like a good way to have differant setups for loads.<br /> I am asking for recommendations as to what to buy, NOT abt. trim tabs ect. (I will be removing my STINGRAY plate though)>>>I need to get the prop dialed in first (have to return the shop loaner). I use this boat as a family runabout, fishing bays, ocean inlets, and calm ocean days>>> and towing my boys around on tubes.<br />SORRY this is long, and THANKS for any help!!!<br />
