OMC outboard
racheljay123
Waste of money? Its a 100hp not sure on the year... runs well now but I just want some opinions on what every here thinks. Will this engine be hard to service and find parts for??
Gary H NC
Re: OMC outboard
Can you post a pic of it? Any model number on the transom bracket?
Basically its the same as a Johnson or Evinrude,just depends on how old it is..
danond
Re: OMC outboard
Try the outboard forums. This forum's for I/O posts.
Vic.S
Re: OMC outboard
to be more specific the Johnson & Evinrude forum. You'll get all the advice you'll need there. Find the model number which should be on a plate on the transom bracket but may also be on a core plug on the engine and it will be easy to identify the year.
Availability of part depends on year but many are available going back for many years.
racheljay123
Re: OMC outboard
:confused:
Oops! Sorry... Im new to these forums but not to forums in general... I should have looked closer! My bad, Ill put this in the right spot but thanks for the help
