Can cleaner
- Aug 10, 2015
- 5
I've got a new to me 20' four winns 200 Horizon with the 5.0. One owner boat and really clean. Aside from a little idle issue took it to the lake and sprung a leak on the trim pump to manifold lines. ( Some how they decided to rest on the exhaust manifold.) Anyhow, the out drive is off as well as the pivot assy. I am some what new to the boating world and am trying to get up to par. I am looking to replace all the rubber bits, looking for a transom service kit. I also need to ID my out drive and haven't had much luck on the world wide web. I would like to put her back together soon with new gaskets, bellows, hoses, fluids and enjoy some more lake time. Been lurking around here for awhile, checked out that hasting omc write up, just trying to clear everything up. Im confused as to exactly what i have so i can search for parts. Oh, and where is a good place to order parts from? I have read the sticky.. the first part for the OMC drive info would not come up for me, just a blank page.
Anyhow thanks
Outdrive - S# T0791890
prod # 3868156
Just found another sticker on the valve cover of the motor that has the following information. Numbers don't match from the palte on the out drive vs the sticker?
Transom Assembly M# 3868175 S# T351236
Drive unit M# 3868175 S#T00793588
Engine M# 502APHUE S# T01280849
Anyhow thanks
prod # 3868156
