OMC Penta 3.0 - Water gushing out of #4
Ayuh,..... Welcome Aboard,...... I'll go with cracked block/ cracked head,.....
Now,..... How 'bout some backstory history on this situation,..??
97Spirit
Bondo - I have no history unfortunately. I just bought it 3 weeks ago. I've only run it on muffs in the driveway. Noticed the misfire almost immediately, shut it down, pulled the plug, found it wet. Replaced the cap, rotor, wires,plugs... no change. Was setting up for a compression test when I saw the geyser for #4. Local marina said the 2 large water jackets at the back of the head freeze and push through the head gasket if not winterized properly (canadian winter). I just don't know if I show start looking for an engine, or tear this one down and see I find a smoking gun...
Forgive my ignorance, but what makes you suspect a cracked block vs. a head gasket?
Thanks
Ayuh,..... It's rarely to never it's Just the head gasket,......
Drain, 'n isolate the block by clampin' hoses, or whatever, 'n pressurize with air, 'bout 10/ 15 psi,.....
Then Listen,...... through any holes ya got, spark plug holes, carb, exhaust, oil fill cap,......
follow the sound to the problem,......
97Spirit
Ah, so basically replace water with air... may point me in the right direction.
Thanks
Lou C
There is water in the center exhaust gas passage that would put water in a cyl, but did you drain the manifold before pulling off the elbow? If not that could explain the water there...the gasket material and lack of rust suggest that the water in the cyl probably did not come from bad exhaust. These engines are very simple to drain, only a couple of drain plugs have to be removed and rodded out....that, and disconnecting the bottom end of the circulation pump on the front of the engine...
