Just a quick question, I am going to install a pertronix system on my 88 460 and get rid of the points, my system has a resistance wire instead of a ballace resistor. The question is how did you run the power wire, do you run it right to the pos side of the coil or do you splice it into the resisance wire? The only reason I am asking is because Rapair suggested to keep the resistance wire in place due to using a low resistance coil.
