alley mechanic
- Apr 15, 2011
- 100
Hello:
I have a question about the omc quick start system thats on my 98 evenrude 115 intruder, when i bought the boat new with this engine i dont ever remember it having the quick start warm up mode where if under 105 degrees it goes into a fast idle and advances the timing 10 degrees till the engine was ovqr 105 degrees , i never had a problem with it starting or dieing out . Well the power pack went bad this summer so i replaced it with a cdi power pack now the quick start works when engine is below 105 degrees. But now what a pain in but you have to wait till the motor comes off high idle to put it in gear as per omc owner manuel says if you put it in gear while in high idle it can damage the clutch dogs, i had our classic this last weekend AIR TEMP WAS 47 DEG WIND 20 TO 30 MPH WATER 50 DEG IF YOU STOPPED TO FISH FOR JUST 30 MIN MOTOR WOULD COOL OFF TO BELOW 105 DEG AND THE QUICK START WOULD KICK IN AGAIN AND WOULD HAVE TO WAIT 4 OR 5 MIN TILL I COULD PUT IT INGEAR DOES ANY ONE KNOW OF A WAY AROUND THIS QUICK START THING.
THANKS ALLEY MECHANIC
