KRH1326
- Sep 22, 2007
- 491
Hey Guys,
This one is a bit aggrevating and frusterating.
Best to start at the beginning, so not to miss anything.
1976 OMC 235 HP Electric shift. This past winter as part of restore job, I installed all new seals and gaskets in both the upper and lower units, as well as the intermediate housing. Included in this work was a brand new impeller and housing.
When I disassembled the unit, the pump pick up tube was rotted away and almost completely gone. According to "aftermarket manuals" ( I have recently located and purchased an original OMC factory manual, just waiting for it to get here.) some models had the tube routed down to the underside of the cav plate, and located right near the prop blade tip, while some models had the tubing routed down to the cav plate and actually drawing water in through the hollow rudder, which is aft of the blade tips.
My cav plate had a hole and screen at both of these locations. From what was left of my original tube, it really looked like it hit the port right above the prop tips, so I fabbed a new tube from copper pipe, and firmly fitted it to pump housing and that port.
This having been my first "wet" season with boat, since rebuilding engine, outdrive etc., I have spent this current season working the bugs out and finding and fixing various problems that have popped up out the blue. All this time, I have had an intermitant over heating issue. I would see the temp climb and chop throttle, would cool off then off I go again. Now I am addressing this problem.
I have noticed that it is happening when I am powered up and climbing out on a plane. Usually at and above 3000 rpm. It was suggested here in these forums that it has to do with the outdrive rising out of the water and maybe losing "suction".
I went through alot of the usual suspects, new thermostat, removed and examined both manifolds and risers. I have GREAT flow through manifolds and risers. So I am suspecting something amiss with the new impeller and housing, or pick up location.
At an idle and under 3000 rpm, I do have copious amounts of raw water coming in. As I am mostly alone, I haven't been able to check above 3000 or out on plane.
As is, this engine does run cool. It hovers between 100 and 140 below 2500. usually 140-160 out to around 3000 and up. Sometimes it stays there, sometimes the heat goes wild.
Just for fun, this morning I hooked up a crank mounted water pump. I just tee'd it into the water coming from the outdrive, heading for the tstat housing assembly. It ran just fine, actually it ran a touch cooler than usual. Didn't break 140 until I was trying to plane. Then it hovered around 140 up to 3500 rpm. At that point , now more confused than ever, I cruised back to mooring.
Now I am sure that it is a prob from pump and housing and down.
Can a pump work fine at lower rpms then crap out at higher rpms? What do you think of water pick up location? Am I missing a place or thing to look at?
Thanks Guys
Thanks Guys
