OMC Sea Drive tilt/trim Problems
BogusSVO
Greeting to All!<br /><br /> I just found you guys, and thanks for being here!<br /><br /> I have a problem and I hope you all have the answser fo me.<br /><br /> I have a 1985(?) 20' CC SportCraft Fisherman with a 1.6L (150hp) OMC SeaDrive.<br /><br /> My problem is with the tilt/trim hydraulics.what it is doing is it want to "slam" back in to the trasom under load,above about 2300rpms.<br />It will hold the outboard over night with no leak down,I marked the rod with a black felt tip on the rod of the upper ram,no leak down in about 20 hours. I changed the hydraulic check valve block out with a used on that I bought. still doing the same thing. this is on the upper ram. <br />Is this meaning that my ram is bad?<br /><br /> I did a search and did not find anything like this. But I did get 20 hits total in the search.
OBJ
Re: OMC Sea Drive tilt/trim Problems
Hi bogus....glad ya' found us....<br /><br />What may be going on there is a bad Oring in the cylinders. You've probably by now have figured out that the cylinders are pistion driven. The sealing force around the pistons are orings. One to a piston. I would really recommend a service manual for troubleshooting the unit. Iboats have the generic version but OEM manuals are the preferred manuals. Manuals for yer engine are still available from any Johnny/Rude dealer. Hope we have helped a little.
BogusSVO
Well I think I get to wear the "Dunce" cap ...I know more about cars than boats, I think I have been trying to fix somthing that does not need fixed.<br />I will post with the new questions.
