OMC sealing compound substitution
sprintex
To reassemble the water pump on my 1988 Evinrude 88 spl You are supposed to use OMC Gasket sealing compound, for under the gasket, OMC Adhesive M for the impeller o ring. Since I do not have these products on hand could I use something else like Permatek for the gasket? And I have no ides what I would use for the OMC Adhesive M. I just don't want to buy a tube of some expensive OMC stuff that I will never use again.
F_R
Re: OMC sealing compound substitution
Permatex with the brush in the lid will work fine for the gasket. As for the o-ring, any stickum to hold it in there till you get it installed will be OK. None of those particular applications are critical.
Chris1956
I used some silicone to glue the Oring into the pump housing. I also used the Permatex wit a brush on the SS insert, as spec'd by OMC
