1988/89 Cobra 350/5.7<br /><br />I am getting ready to prep for summer in a few weeks and need some advice on some issue I have with my outdrives.<br /><br />1) Hard Shifting: Both engines shift "into" gear very, very hard. Not all of the time, but about 90% of the time. They seem to shift "out" of gear much more easily. The PORT shift cable is worn through the PVC cover, and I will be replacing that one. The other one looks fine. I have manually attempted to enguage the ESA. Stb. side does scatter the ignition, but the PORT side does not. I have not been able to locate any replacement parts for the ESA (I'm sure they're not cheap!).<br /><br />2) STB side outdrive clunks every 5 seconds while in "REVERSE" only, as if the gears are disenguaging and reinguaging. I'm not sure if this is a gear issue, or a simpler adjustment.<br /><br />3) (shallow water maneuvering) When drives are in 50% or higher "UP" position, shifting is near impossible. Either won't enguage, or will stall out the engine when enguaged. (STB only).<br /><br />4) Odd: PORT side prop will spin while in Nuteral. I can physically stop the prop by hand. There is a very slight pressure on it, and when I let go, it will spin freely again. As if it is alost in gear, but not quite. Not sure how to troubleshoot this, and I thought the shift position was either IN or OUT of gear, not somewhere in between.<br /><br />I bought this boat two years ago from it's second owner. The engines had about 370 hours on them. Since I bought her, I have pulled the outdrives each year and greased them. I actually replace the STB engine last Spring due to a winterizing debockle. All of these issues have existed since I bought the boat, they have not gotten any worse since. I am very capabable of doing the service work, I just need to know where to start. I have SELOC manuals, and have the HASTINGS white-paper on adjusting shift-cables.<br /><br />I really want to use her a ton this summer, so I want to make sure I get everything in tip-top condition again.<br /><br />Any suggestions, advice, tips etc. will be greatly appreciated.<br /><br />Thanks guys!<br /><br />-David
