OMC STARTER WONT TURN FLY WHEEL
hopscotch
HELLO ALL <br />I HAVE 87 BAYLINER WITH A 4 CYLENDER I/O<br />I REMOVED THE STARTER AND HAD IT RE BUILT DUE TO IT JUST HITTING THE FLY WHEEL AND MAKING THAT SCRAPPING (NOT ALL THE TIME) SOUND WHEN I RE INSTALLED IT IT STILL MAKES THAT SCTAPING SOUND (ALL THE TIME).THERE WERE NO SHIMS THERE WHEN I REMOVED IT. DOES ANYBODY HAVE ANY IDEAS I AM LOST THE MOTOR IS NOT SEEZED <br />THANK YOU <br /> :confused:
olbuddyjack
Re: OMC STARTER WONT TURN FLY WHEEL
Would that be a Cobra 2.3 or a Mercrusier 140? Little more info please...<br /><br />In either case hows the teeth look on the flywheel?
hopscotch
HELLO <br />IT IS A Mercrusier 140THE TEETH LOOK FINE
boathog
wrong starter or wrong rotation starter?
Bt Doctur
ring gear may have cracked loose and slipped too far back
hopscotch
SHOULD THERE BE SHIMS ON THE STARTER?<br />WHO MAKES THE MOTOR IF IT NEED TO BE REPLACES ?<br />CAN YOU DO IT WITH A CAR ENGINE?
boathog
did that starter start the motor this year or just last year.
LOOSE THE CAP-LOCK,...........<br /><br />The Teeth of the Starter might be Fine,.... How about the Flywheel......??<br /><br />Did the RebuildShop install a New Bendix,.??<br />
OMC STARTER WONT TURN FLY WHEEL IT IS A Mercrusier 140
So,..... Which IS it,...???... OMC,... Or Mercruiser,..???....
hopscotch
I dont know if the bendex was changed <br />sorry for the cap locks the teeth on the starter and fly wheel look ok ?
boathog
ck voltage and batt connections
Bt Doctur
Lets see:motor was running at some point, starter was making a grinding noise,rebuilt starter , still makes noise. =loose/broken ring gear, ring gear too deep.<br />measure from ring gear to block mounting bolts,, compare with bendix extended to starter bolts.
hopscotch
ok bt doc i see where you are going with this <br />when they rebuild a starter what should be done ?<br />thanks for your help<br />hop
Bt Doctur
normally: establish the rotation of the starter,disassenble, bead blast housings,clean and true armature, replace brushes,replace bendix,lube, assemble, bench test.<br />only other time youll get that noise is if the bendix drive is bad and wont lock up internally, most have 4-8 ball bearings that jam in the housing to lock it up for starting and allow fow over-run when the motor starts.
