fazerpaul1970
- Sep 5, 2015
- 16
Hello from Holland,
Being new to this forum I first of all wanna say thanks for making this a great place for helping boat owners solving their problems!
Okay, here's my problem.. ;-)
I recently bought a vintage Tullio Abbate speedboat with an OMC V8 235 HP engine and a Stringer electric shift outdrive. On the engine there's a tag saying the engine was built in 1971. When I toke the boat to the lake for the first time shifting was good and smooth. On my way back to the harbour speeding around 3500 rpm, suddenly the drive lost forward gear and the engine revved up fast. I pulled back the lever and shifted into neutral, then tried several times to shift into forward gear but the clutch didn't lock anymore. So I had to drive the boat back in reverse gear, which made me the hero of the day at the marina, lol!
Today, a friend and I tried to figure out what went wrong with the shifting. We checked the leads going from the shifter lever to one of both large connectors on top of the engine behind the carb. I disconnected the leads at this point and we measured voltage for forward and reverse coils while moving the lever. Both leads gave us a solid 13,3 Volts with fully charged battery. Then we measured the Amps going through the same leads and we got 2,12 Amps for both coils, is that okay?
When shifting into reverse you can hear a solid click in the lower unit, while shifting into forward there only is a faint click. I tried to spin the prop and it nicely locked in reverse but in forward it spins with a rattling sound or sometimes it lockes but under load falls back to neutral.
We also checked the lower unit oil and it was totally black and free of any metal chips. I know of the dark green colour of Mercruiser gear lube but how about this black lube, is this the type C lube?
So.. any ideas of what happened to my vintage oudrive?Any help is greatly appreciated!!
Thanks,
Paul
Thanks,
Paul
