OMC Stringer Shift Cable.. where does the spring go?
danthern
Hi Guys....1977 OMC 235 hp with 800 series Stringer outdrive. Installing a new water pump kit. When I dropped the lower unit it remove the raw water pump, the shift cable is revealed. There is a spring clipped to it that obviously connects somewhere else at the other end. Don't see it in the manual. All advice appreciated.
Bt Doctur
Re: OMC Stringer Shift Cable.. where does the spring go?
If im not mistaken ,there is a hole in the intermediate housing casting that accepts the spring.
Boomyal
1977 OMC 235hp is an electric shift stringer not an 800 stringer.
danthern
It is electric shift....I stand corrected. I'll look for that hole in the intermediate....Thanks Gents!
fendersfender
yep...just a retainer that bolts to intermediate housing to hold cable in place
