kissbass
- Jul 9, 2007
- 7
I have a problem with my system check, Evreytime out it will go thru the system check numerious times for no reason just running along and it will go thru the system check, No change in the motor,or water pressure. The local mech. said it showed no codes set in the computer, He said it was probibily a loose connection but I have check and evrything seems tight. I have to replace the EMM last year and I went with the more expensive OEM. I thought that might be my problem but it didn't change. I even thought it might be the key switch but I have wiggled it while running and it did not cause it to do it. Anyone got a clue what would cause this?
