Thanks. I suspected that, but I wanted to make sure. What terminal on '74 70HP Evinrude should the pulse come from? I see two, one with a gray wire and one next to it with a gray/yellow wire.
The schematic is wrong. The SEND terminal is not switched +12V as shown, that terminal should have the pulse line (SEND) from the engine. The IGNITION terminal should have switched +12V on it. It doesn't matter what the orientation of the terminals on the tach is. The labels on the tach are correct. The sources are wrong.
Yes, however you want to look at it the schematic is wrong. The directions say do not deviate from the wiring but if you follow the schematic you're wiring it wrong. I wonder if Teleflex is aware of this error.
