OMC throttle cable adjustment
motox6
Is there any specific way the throttle cable needs to be adjusted? I just replaced my engine and it runs fine on muffs, once in water only 2000 RPM. I fiddled with the cable end connected to the throttle body and I eventually got 4200 RPM. Any help appreciated...
Re: OMC throttle cable adjustment
find the specs for neutral ideling then set it to that. that is usually the way to go. if it seems to low give it just a little at a time. but remember not to have it to high in neuteral so you dont smack the drive into gear when u shift up.
motox6
been there done that one time trying to get the boat out of the water-hope I did not hurt it.....
