Re: OMC Tilt question
Taffy<br />You can raise it some at low rpms without damage. I have a 1980 Series 400 and have always raise it up to 45 degrees when backing into a beach or very shallow water but at idel or just enough power to move slowly. Never had any problem with the ball gears. Just remember to put all the way down before bring up on plane. You can use trim at all speeds but tilt only at idel.<br /><br />Just for fun checked my owners manual for my 1980 model. It covers 120, 140, 185, 200, 230, 260 hp.<br /><br />"NEVER ATTEMPT TO PLANE THE BOAT WITH THE DRIVE UNIT IN A PARTIALLY TILTED POSITION. However, in an emergency, the unit may be tilted and the boat operated for very short periods if no greater power than is necessary to move the boat is applied. Tilting the unit reduces the draft of the boat for emergency operation in shallow water. ALWAYS RETURN TO THE FULL DOWN POSITION AS SOON AS POSSIBLE OR COSTLY DAMAGE TO THE DRIVE TRAIN COMPONETS COULD RESULT."
