Re: OMC timing issue
Howdy,
If I remember correctly, you would time it either 8 or 6 maybe BTDC? (advanced with premium gas, retarded for 87 octane regular.)
Maybe it was 8 and 10 degrees. either way, you want to make sure that you run premium if you run it advanced or you could have a detonation event!
I think you either have a couple of spark plug wires reversed, your vib-damper might have slipped, you're reading the numbers wrong, you're using an adjustable timing light and it's not set at "0" OR you may have even had a timing chain jump a tooth.
Also, look closely at the distributor. (electronic?) does it have centrifugal advance (Pertronix) or is it electronic advance? (MSD etc?)
