OMC Trim doesn't Work
lilb
I am helping a friend with the trim issue on his boat. 1990 Baja 240 es with 460 king cobra and the trim doesnt work at all. We will be working on it in the morning again because we ran out of sunlite. I was wondering if i could some how run jumper wires to the battey to see if it goes up or down. If so would anybody know what color wire works up and what color works down? And if it works that way what else to look for? Thanks
dubs283
Re: OMC Trim doesn't Work
blue = up (sky)
green = down (grass)
if by jumping it you get it to work, look for loose connections/corrosion in the wiring
lilb
Thank you for the info. I will try that out in the morning
lilb
Well today as soon as we turned on the batteries the lower unit started going up all on its own, pushing the trim up/down stops it but doesnt go up or down after that. weird. then wit it sitting with the batteries on after 5 to 10 minutes it starts going up by itself again.
Now i am just confused and wondering what would cause it to have a mind of it's own like this? Bad switch, Bad wireing? Somthing wrong with the pump relays?
dubs283
you need to start troubleshooting the wiring
start at the pump assy and work your way to the trim button
you will eventually find the problem
lilb
Well got it all figured out after rewiring from the switch to the pump. It was the fuse for the pump. I can't still figure out why it would work on it's own with a blown fuse, but o well at least it's done.
Don S
Mechanical things don't heal. You still have a problem. Only now it's an intermittant one. Much harder to track down.
