OMC Trim/Tilt
Riverdance
I have a 1993 FourWinns Cruiser w/twin 351 King Cobra engines.Starboard engine sterndrive tilt works fine.Port engine outdrive does not go up or down nor do I hear a motor trying to raise or lower it.Any list of possible remedies would be appreciated.<br />Bill
Re: OMC Trim/Tilt
Broken or Loose wire ?????????
BigBabyLou
Re: OMC Trim/Tilt
Bill, do a search for "trim" or so on this forum and you will get numerous hits. Read through the posts, they often describe the same symptoms you are having.<br /><br />Check the solenoids if they have power or if they send power to the motor. Also, every outdrive has its fuse. I don't know how it's on a dual engine boat. Maybe you just blew a fuse on the port outdrive.<br /><br />Run the search and you'll find lots of good advice.<br /><br />Lou
Riverdance
Re: OMC Trim/Tilt
bondo- couldn't find any loose or corroded wires<br />Lou- Do you have any idea where the fuse might be located on the outdrive?<br />Bill
BigBabyLou
Re: OMC Trim/Tilt
Bill, if you have a repair manual, it will tell you where the fuses are. If you don't, there is nothing to lose by getting one. It's a very good investment.<br /><br />My outdrive lifter pump fuse is on the aft of the engine block, right by the big connector and other main fuses. But I have a different boat ('89 Bay Cierra 2655 w/ 460 King Cobra) so it's hard to tell where exactly yours are.<br /><br />If you don't have a manual, just locate the wires from the malfunctioning pump and trace them back to relays (plastic boxes somewhere 'round the engine) and trace the other wires from the relays to the battery. These wires should have fuses in them. But since you're already looking at the wires and solenoids (relays), check the voltage with a test light or voltmeter.<br /><br />If you need any specific info on what and how to check, let me know, I'll be glad to help.<br /><br />Lou
