tkwbigtwill
- Jul 1, 2003
- 11
I replaced my lower omc gearcase on my 88 4.3L Four Winns with a GLM unit.I also replaced impeller on water pickup pump.I put muffs on and started engine but could not get water to flow thru system.I noticed that the GLM unit does not have the small hole in front of the water intake slots.My omc always had a small pencil stream of water from this hole when the muffs were used.Should the hole be there on the GLM unit?? I removed lower gearcase and found a very small leak in the water passage housing thru a pin hole in the casting. I turned water passage over,filled it with water,and had a drop of water every second leak thru casting.Could this small leak in water passage housing keep water from reaching impeller?? I put my OMC gearcase,with a bent prop shaft, back on and water flowed like it should. Help me if you can,Terry
