omc went bang after 20 min.
russman
(1973 wes craft 19', 307 chev, omc sw-131e outdrive)<br />last weekend went out for first trip to the lake of the year.<br />ran motor 5-10 mins no problem then ran it 20 mins. motor/outdrive went bang, motor stopped wont turn over had to be towed back to ramp.<br /><br />got it home removed the out drive, motor turns over runs fine.<br /><br />out drive locked up cant turn coupler<br />prop turns free, oil still in unit<br /><br />does it sound like the outdrive is cooked?<br />is there anything easy to check to verify this.<br />is it worth repairing?<br /><br />thanks in advance<br /><br />russman
Wart T
Re: omc went bang after 20 min.
Drain the oil see what comes out. Sounds cooked to me.
KaGee
Bet you have water in the upper unit. The only way to isolate is to separate the upper from the lower and drain both. <br /><br />The "bang" though has me concerned, that sounds like a major failure. Hope the casing is ok.
