I have a 1989/1990 vintage OMC outdrive .. new carb but place out of business and didn't tune throttle travel correctly. I have the OMC side mount control (concealed version) with only the handle and trim control on it visible. I have trouble starting without starter fluid, and it appears to me the throttle cable needs another 1/4" or so movement to be fully open and to allow me to initially pump lever for some fuel to squirt into carb. High end speed also gone which also matches. When I opened control box I don't see anyway to adjust the throttle distance (idle is fine) and on the carb side I se one black plastic cover over end which looks like it might adjust but that would seem to only move the throttle more advanced .. I like idle where it is. And finally when I hand push the throttle on the carb it opens the butterfly valves to fully open with that 1/4 distance ... otherwise appears the second two barrels stay closed. Any help appreciated ... will try and upload some pics.
https://www.amazon.com/photos/share...BS2oJ0ajlPOeAN/gallery/8IcsXieASrmoimhwy3un4A
