omg help
renny1
well i have replaced impellor and water pump and all seals and also decided to rub down sterndrive and prime and paint BUT in doing this i turned the prop and now its out of gear so obviously i dont assemble whilst out of gear(or do i) so can you tell me how to put her back into gear please
Fishermark
Re: omg help
Is this an alpha? Simply turn the shift shaft all the way clockwise while turning the prop counterclockwise till it locks in place. This shaft pictured here:
Surfdancer
Re: omg help
Same thing... No biggie. Spin the prop to verify.
Also, these drives like to stay in forward when positioned like the drive is tilted up and out.
Re: omg help
Ayuh,...
I wrap a bungee strap from the cavplate, around the propshaft, back to the cavplate,...
It'll hold tension on the gears,+ Keep it in Forward...
renny1
Re: omg help
bungee cord on
thanks i thought i had done something which was a big problem lol
