nola mike
- Apr 22, 2009
- 5,695
Finally got back on the water after a ton of rain. Was trying to see whether I could get the temps up after flushing the HX. 17 miles each way to our destination, running it a bit harder than usual, 33-3400 rpm on the way out, way back with a few longer runs at 37-3800 rpm. Stopped on the way back for a swim. Started no problem, got on plane. Maybe 30 sec later the engine just died without warning. Started right back up, went another maybe 6 miles without issue. Engine then started missing a bit, then a bit more. Slowed down a bit and it seemed to improve. Was near home and didn't push the issue. Wiggled the plug/other wires a bit to make sure nothing was loose or frayed. Pulled the coil wire and noticed a bit of oil on the terminal, and a little in the coil. Also noticed some hissing/sizzling around the screw inside the coil plug. Coil didn't seem particularly hot, so I figured it was oil leaking from inside. I'm going to be weak and replace this before it leaves me stranded, but I don't want to disappoint scott Danforth
Can I use any generic external ballast auto coil (I have a Mallory electronic ignition still using the resistance wire)?
