on 1 cylander sometimes
ace420ace
Hi all i recently bought a 1981 johnson 15 hp, it runs good intermittantly i am pretty sure one cylander is working than quitting seems to run better cold, i just did a decarb and put new plugs was running good on both cylanders for 15 min, then bog down to 1 after some hesitation got it back to two off and on, checked new plugs after 15 min and both were white/tan. too lean but gas is mixed 50 to 1, carb just rebuilt, idles fine problems come at wot or close. any info greatly appreciated.
thx
ace420ace
and does richening the slow speed adjust knob affect half throttle or wide open?
Run with a timing light and observe behaviour of spark.---Test each cylinder to full throttle on the lake.
kbait
Check coils/plug wires for arcing (easier at night). Also, check the bundle of wires coming from under the flywheel for cracked/frayed - especially where they flex due to armature plate movement w/throttle. Check both cd box plugs (pull apart and make sure the pins are in place correctly and not corroded. Make sure coil grounds are both clean/tight.
Good luck and welcome aboard!
ace420ace
ok will check for arcing i looked at all wires looked good, not sure what a timing light is,if electrical what cause to run lean? also before decarb went to full throttle and died after rinning wot for a min like wasnt getting fuel but hasnt done lately its seems like second cylander is sputtering trying to work at half throttle. thanks
ace420ace
there is also a red wire that is not doing anything it just loose, i figure was for electric start.
ace420ace
ok I have a timing light and was told how to use but is it ok to hook up to a 12 volt battery or do u have to hook to motor to get power? I checked the spark with spark tester both jump 7 16. thanks
ace420ace
ok guys I took it out on the lake tonight with a timing light spark is normal on both from idle until half throttle from half to wot bottom cylinder missing and spark erratic as well. the bottom cylander kicked in a few times but when slowed down and went to speed up again it was erratic again. also the bottom plug was wet top good. is this a coil problem?
