Re: ? on poly and or epoxy
You are mixing two different types of failure, actually three, rot from water, not strong enough (as in under built) and the bond.
With how most transoms are put together it won't make any difference which resin is used, the failure is from unsealed screw holes, poor designs, sloppy workmanship, etc. It needs to be done correctly with any of the possibly products.
If it was designed to be strong enough with epoxy and it wasn't built up to spec, it would fail also. From the exact same set of production based issues that take place when hand built products are mass produced by poorly trained employees. First comes the leak, then rot, resulting in a big repair. It makes no difference which resin is used, if water gets in, the wood will rot. An unsealed screw hole doesn?t know if it went through polyester or epoxy, and the water doesn?t care either, it flows in and is sucked up by the wood, the barrier layer (resin) doesn?t make a difference in this failure.
A boat built with epoxy would be no stronger than one built with polyester, it would be lighter, but not stronger. The reason is the design is engineered to be a meet a certain specification, if stronger products are used, then less of it is needed to meet the spec. If you used the same amount of each product, then yes it would be stronger, but that?s not how products are designed and engineered.
Another failure is from uncoated wood, again if the wood isn?t sealed, it makes no difference which resin is used.
Another type of failure is from the product not being built up to spec. Not enough glass, the wrong kind of glass, unrolled glass, poorly cured resin, etc. Again, it makes no difference which resin is used.
Now a poor design. If it wasn?t originally designed to withstand the stresses it will see in use, it will fail, and again, it makes no difference which resin is used.
I have watched thousands of boats be built while auditing production plants to help fine tune procedures, some plants do a good job and some don't.
In the 60's and into the 80's there were hundreds of small, sort of fly by night companies that built cheap stuff and the wood rotted out, many of these are what get discussed here. As time went on production methods were improved, but still relied on each worker to do a good job and that's the problem.
From what I see myself, hear about, and read on this site, it appears water making its way past the skin through unsealed or poorly designed areas is the main issue, the bond doesn't come into play, in fact many people have a tough time removing the plywood that's not rotten. Frequently pry bars, hammers, come alongs, circular saws, chain saws, etc all come into play when trying to remove the good wood. And as I said before, if the glass was still bonded to the wood, no matter how poor that bond may be, it survived the real world and worked as designed.
Now if we?re talking about building a wood boat, it makes a big difference in which resin is used, but that?s a completely different subject.
