Onboard Charger not working????
tprice
I have 2 onboard chargers on my boat. One is for the trolling motor batteris(guest 2 bank 20 amp) and the other is for the starting battery and electronics battery(BPS 2 bank 8amp). I installed the BPS charger a month or so ago and it was working fine. The other day I plugged it in and I always open the bilge hatch while it is on and check to make sure the lights are on. Well the other day I plugged it in and no lights. I did the normal checks of the ext cord and everything else and even plugged it into the other onboard and it was working fine. I double checked eveything for loose connections and such and still not go.<br /><br />Before I call is there something I could have missed??
BayStealth
Re: Onboard Charger not working????
I'm not familiar with those chargers, ck if there may be a 'Reset' switch or breaker, if not, take it back cause its bad...
