saumon
- Aug 2, 2004
- 1,452
Setup: 1993 Tracker (aluminum) Pro Deep-V 17 with Mercury 60hp 2-stroke. A gr.24 cranking battery in the bilge area for starting and running accessories (GPS, depthfinder) and a gr. 31 battery in front for the Minnkota 55 lbs Powerdrive.
Being tired of removing and hauling the big battery for charging, i bought an onboard charger (3 bank, 15 amps). I installed it under the side console and hooked one of the output to the trolling battery. My main concern is for the starting battery: being like 15 feet from the charger, can i hook the second output onto the bus bar (always hot) that was under the console (that's what i plan to do)? Or do i have to extend the output wires to reach the battery?
Thanks.
Steve
Thanks.
Steve
