rsimmons42
- Aug 25, 2008
- 194
OK, purchased boat about a two months ago and took it out, boat would idle but would not run when put in gear. Engine is a 1977 Johnson 70 hp(Model 70EL77S) I then completely rebuilt the carbs, replaced the fuel pump, replaced the fuel lines, and replaced the rectifier. Did a sink and link as best I could. Took the boat out last weekend. Was able to get the boat up to a plane, but would only travel at 29-30 mph (gps) Boat is a 1989 16' Sunbird. Don't know if this is a decent speed for this engine and boat. The engine sounds just a little bit rough. I looked at the plugs in it today and noticed that the plugs are Autolite 2634, I replaced them with Champion L77JC4's. Now here is the Question(s).
Is the Autolite plug compatable?
If not could this of caused the problems.
Compression is #120 all three cylinders, and the spark was about 3/4 of a inch with the new plugs.
Please let me know what you can.....Thanks
