One Funny; other makes you go Oooo....
eeboater
Q: Did you hear about the new low fat communion wafers?
A: They're called I can't believe it's not Jesus
Q: What's the difference between Heath Ledger and jokes about Heath Ledger?
A: The jokes are getting old.
roscoe
Re: One Funny; other makes you go Oooo....
Ooooh Sean, you need to get out more. :)
bekosh
You might not have known this, but a lot of non-living objects are Actually either male or female.
H M M M . . . ?
Here are some examples:
FREEZER BAGS: They are male, because they hold everything in, but you can see right through them.
PHOTOCOPIERS: These are female, because once turned off; it takes a while to warm them up again.
They are an effective reproductive device if the right buttons are pushed, but can also wreak havoc if you push the wrong Buttons.
TIRES: Tires are male, because they go bald easily and are often over inflated.
HOT AIR BALLOONS: Also a male object, because to get them to go anywhere, you have to light a fire under their butt.
SPONGES: These are female, because they are soft, squeezable and retain water.
WEB PAGES: Female, because they're constantly being looked at and frequently getting hit on.
TRAINS: Definitely male, because they always use the same old lines for picking up people.
EGG TIMERS: Egg timers are female because, over time, all the weight shifts to the bottom.
HAMMERS: Male, because in the last 5000 years, they've hardly changed at all, and are occasionally handy to have around.
THE REMOTE CONTROL: Female. Ha! You probably thought it would be male, but consider this: It easily gives a man pleasure, he'd be lost without it, and while he doesn't always know which buttons to push, he just keeps trying
