DonKnutson
- Aug 7, 2010
- 4
Have an '07 Glastron GT185 with 4.3, Volvo Penta outdrive. Have had the boat in the shop three times due to a failure of the single lever control to engage into gear. Symptom: Push the button in and move lever forward to start...it all works fine. Return lever to neutral after a start and it too often refuses to engage into forward or reverse. Shop has had it apart three times after getting towed off the lake or off the lift. Last fix, shop replaced the main cable. It is marked as a Volvo Penta single lever control. Have others had this problem? Is there a simple fix it get the button to "pop back out" when it appears the button is locked in the neutral position? (Original owner boat, low hours, always top maintenance....tired of getting stranded.) Thanks.....
Worse case scenario...if I were to replace the control, what brand would you suggest?
