Re: Online source for warning buzzer?
I bought a '96 faststrike on ebay without a harness, turns out its a '95, unfortunatly I was so excited I bought a harness and sys check tach for a '96 before I actually got the motor. I got the tach and harness on ebay for $30 so no big deal but I did still want to use the tach so I cut the lead from the harness to the tach to retain the 8 pin connector and about a foot of wires to splice into, tach works fine. Vro is disconnected, and I think there is only the two water temp sensors to hook into, I spliced all off the sensor wires coming out of the tach into the one water temp lead from the motor so that all the lights on the gauge would light up if there was a problem. Is there actually supposed to be an audible inside the tach? Dont these audibles just ground out via the sensor to operate?
