ONLY RUN @HALF OR OPEN THROTTLES
COSMA
1997 FORMULA SUN SPORT TWIN 454 JUST GOT DONE <br />PUTTING IN MANIFOLDS AND RISERS DID IT MYSELF.<br />THAT WAS PRETTY INTERESTING TO SAY THE LEAST.<br />GOT TO START STBD RUNS GREAT PRT WILL NOT START <br />UNLESS YOU HAVE HALF OR BETTER THROTTLE RUNS FINE<br />GO TO BACK OFF SHUTS DOWN CLEANED CARB <br />CHECKED GAS TO CARB FINE/CHECKED TUBE TO FUEL PUMP<br />NO GAS WILL RUN AT 2200RPMS. SOMEONE SUGGESTED IT SOUNDS LIKE THE PTS ARE CLOSED OR A VACCUUM LEAK.ALSO THERE IS A SQUEALING NOISE SOOUNDS LIKE BELTS ARE SLIPPING WOULD THE CIRCULATING PUMP IF BAD MAKE THAT NOISE... IT GOES AWAY WHEN THROTTLING THE ENGINE.<br /><br />IF ANY BODY IS A MENTOR THAT KNOWS MERCRUISER 454 <br />AND HAS ENCOUNTER THESE PROBLEMS YOUR INSIGHT WOULD BE HELPFUL
crazy charlie
Re: ONLY RUN @HALF OR OPEN THROTTLES
Did Port start well before the man. and riser change??Charlie
crazy charlie
Then that tells you it was something you removed or tinkered with while doing the work on it.Back-track and try to find what did not get back together the way it was before you started.Charlie
