OK, the little 1958? 2hp elgin that finally started running well was doing so on a 15 to 1 mix of Stihl Chainsaw Oil and our local regular gas with 10% ethanol.
It was doing so well that I mixed gallon of gas with sears 2 stroke air cooled oil at 16 to 1. The sears oil might have been 10 years old but never opened, foil seal intact. I am very precisely measuring the gas.
Test spin on the lake and after 10 or 15 minutes at full throttle, power starts dropping off, motor runs slower, finally dies, wont restart-and is much harder to turn over.
Back to shop, lots of spark, I cool it down with air, mix another batch of oil with the Stihl oil and gas at 15 to 1. Now, it takes a long time and alot of pulling, but finally it starts, barely runs for a while, and at last takes off strong in the test tank. Back to the lake, runs well at full throttle for a long time, no more issues.
All this means something, but I am not sure what-it seems borderline that a different oil at a bit higher ratio makes a difference, but it does. Carbon in the head? should I go to a 14 to 1 mix? I am not sure how much oil I can add before fouling plugs, and what is wise, and what I should do for this little motor-as always, your help is appreciated.
