Oops mixed up thrust washers
Alumarine
Hi there, trying to get my boat out for it's maiden voyage and my helper put all my different prop hardware all in the same box.<br /><br />Got some old props that don't use the Flo-Torq II Kit and some new ones that do.<br /><br />I have 2 different thrust washers, one # 12-835467 is solid brass and one with no part # that has a brass body with a Stainless face.<br /><br />Can anyone tell me which washer goes with the old props and which one goes with the Flo-Torq II Hub?<br /><br />Thanks for the help.
tommays
Re: Oops mixed up thrust washers
my 2 flo hubs cam with solid brass thrust washers #991204<br /><br />the step fits very firmly in the prop and as long as it keeps the prop from rubbing on the gear case and tight when you lock up the other hardware you should be ok<br /><br />
<br /><br /><br />tommays
Alumarine
tommays, thanks for the info.<br /><br />So, I guess if the shoe fits...
steve n carol
Please note, that the opening in the middle of the thrust washer is beveled, this fits the bevel on your prop output shaft...sl
