I was out with my '85 15' Procraft Saturday and the motor a 85 Yamaha 90hp lost power and died. After a while I finally got it running again but it sounded different. When I got it home I did a compression test and found that the center cylinder was 50% of the other two. So I removed the head and found the piston liner was scored pretty bad. I need your guys opinion on what to do. Is it a very big job to replace the powerhead for around $2,000? I'm sure I can do it even though I have never worked on a boat motor. I have the Selco repair manual and decent mechanical skills. Or should I just let my local dealer fix it for around $3,500. This way I know it will be done right and what ever happened to make the piston fail will also be fixed. I was told by a coworker that what ever I do I should disconnect the oil injection system and just add the oil to my gas. Or should I just put the head back on, make sure it starts and trade the boat in on a new Triton.
