Opinions needed
jtmarten
Master Chief Petty Officer
I just pulled one of my drives, intending to replace the gimbal bearing, bellows, water hose, lower shift cable, and tilt/trim senders for both. After having the drive off and inspecting everything, it all looks like new. Gimbal bearing is nice and smooth, zero evidence of bellows leaking.
I'm very tempted to just replace the lower shift cables since I'm pretty sure they're bad (very hard shifting, esp starboard), and having the remaining parts onhand if I do have an issue this year.
Thoughts are greatly appreciated!
Thanks
Don S
Re: Opinions needed
Does the engine die when shifting into or out of gear????? If not, then your stiff shifting problem is not in your lower shift cable.
achris
More fish than mountain goat
Re: Opinions needed
Errr, what are we talking about here? Alphas, bravos, Gen I, Gen II.... How old are they? As #5 would say "Need more input".
Chris......
jtmarten
Re: Opinions needed
Stbrd side died about 85% of the time last year when going into reverse, 15-20% of the time going into forward. Aggrivating. Port side occasionally died going into reverse.
jtmarten
Re: Opinions needed
Sorry, twin 350/Alpha 1 Gen 1; '86 Wellcraft Nova II.
achris
Re: Opinions needed
If they haven't been replaced before, then it's a high likelihood they need doing now... Stalling on going into gear is usually (95% of the time) a lower shift cable. But you should also be looking for why they failed.
Usually it's a leaking shift shaft seal in the bell housing, especially your era... Merc released a new seal... I'll look up the bulletin and post it back here...
Chris......
achris
Re: Opinions needed
Here is the BULLETIN... read what is says as 'Problem'.... :D
P.S. I never owned the installation tool... I just made one up out of a long bolt, some washers and a nut... :D:D:D
jtmarten
Re: Opinions needed
If it's the upper shaft seal/bushing, I bought a transom kit that includes them.
jtmarten
Re: Opinions needed
Thanks! I'll replace those along with the lower cables.
jtmarten
Re: Opinions needed
What's the configuration/use for the tool? The transom kits I bought include the upper bushing/seal and the lower bushing along with the shift arm.
The install tool is $22, but if I can make one out of scraps that'd be much better!
Thanks!
smokeonthewater
Re: Opinions needed
DEFINATELY replace your driveshaft bellows and shift cable bellows also while apart.....
achris
Re: Opinions needed
Thanks!
Don't take this as an insult.... If you can't work out how to set up a bolt, washers and nut to 'press' in a bushing, then maybe you should be having the rest of the job done by a mechanic.
Chris........
chriscraft31
Re: Opinions needed
Replace the bellows while its apart. If you park the boat with the outdrive up and there is a small leak you will return to find your boat sitting on the bottom.
achris
Re: Opinions needed
This is contrary to manufacturer's recommendation.
If there is a small leak, regardless of the drive being up or down, the boat will ship water...
Chris......
chriscraft31
Re: Opinions needed
A friend of mine lost a 26' carver because the bellows (shift linkage bellows) and I had a near miss with my ski boat parked on the beach overnight with the outdrive up. I would replace them if over 5 years old .
jtmarten
Re: Opinions needed
Chris........
None taken, I just haven't had an outdrive for about 7yrs (man I miss my jetdrive!) and have never had one apart. After looking at it, pressing it in/out is a waste of time. I used an old 3/8" long extension, a male allen/hex socket to start pressing them out (kept it centered nicely since they were flush), and an old properly sized socket to knock them out. Took about 3min total to r&r both. Now just waiting for the rain/snow to go away so I can r&r the lower shift cable.
