oldrem
- Nov 7, 2013
- 2,002
The carpet is sitting directly over badly water soaked foam which needs to come out and replaced. The transom has stress cracks - not due to rot, but because someone in the past thought 4 layers of 1/2" cement board would be a good material for a transom. It has since been reinforced with some perforated steel channel and bolts, but it all needs to be cut out and replaced. I'm planning on cutting out the whole transom and replacing with 1-1/2 to 2 inches of marine plywood, (3-4 layers of 1/2" epoxied together and well coated with epoxy). Then glass it all in.
The wiring for the lights has been cut, so I'll fix that too as well as redoing the bilge pump and possibly re-rigging the live well.
Just at the planning stage since I won't be able to due much on it this fall or winter. Any comments or advice would be helpful.
Was going to include photos, but it won't let me.
