op's on what to do with my through hull exhaust (video)
weider1717
My exahust as you'll see in the video sits at the water line. Half of the exhaust is like above the water line and have is in the water, it's got a nice tone to it in the water but I wish it was a couple inches higher so I get the complete roar of the 350 v8.
anything I can do? do they make some kinda attachments to bring the exhaust exits above the water more?
thanks
http://s22.photobucket.com/albums/b347/weider1717/?action=view&current=MOV00511.flv
alumi numb
Re: op's on what to do with my through hull exhaust (video)
get some polished stainless steel tubing with a 90* mandrel bend.
hook up to the existing exit point and run them straight up with flapper caps on top.
kind of like stacks on pick up truck.
you would have to have then compound bent to fit between the platforms and lower unit but i think it would look great.
it's not like they would be sticking out or anything, looks like they would blend in well.
windsors03cobra
Looks and sounds great I would not change a thing.
Surely you hear 90% of that screamin chevy.
weider1717
actually is has a good bit of bubble sound to it since the exhaust is is half and half at the water line..
Ayuh,...
Haven't you already asked this question before,..?? I seem to remember already answering it....
As I said before,...
If you put Any Up-angle on the exhaust,...
The Water will run Back Into your motor.....
Besides,...
As soon as there's forward motion to the hull,...
The Exhaust Tips will be Out of the water,+ the NOISE you're looking for will be there.....
weider1717
i perfer to hear the engine caddy at idle and low speeds which I don't really get now though.
if I did anything I think i'm smart enough to make it where water can't run into the engine...:)
ziggy
if I did anything I think i'm smart enough to make it where water can run into the engine...:)
:eek:
i'd leave yer thru hulls alone too...
alumi numb
sounds like a pro to me.:D
weider1717
Ayuh,...
Besides,...
I did ask this awhile back but I could give a crap is you answered it back then or not...since when have I ever chose to take you serious and use your advice? you're just a smartbutt that thinks he knows it all...when you're just a grease monkey!
lol this is so funny.."I seem to remember already answering it...."
who in the hell cares if you did lol...
zach103
here we go again lol.. more fighting
Weider im not a pro so maybe my advice won't help at all but im gunna try .. can you put like 2 small 90's closer to the engine so that the exhaust pipe is higher than sort of angle it down at a slight angle but enough where water cant go up it.. . . but than you would have to cut new holes and fix the old ones.. thats all i can think of right now but like i said im still a newbie.. but ill think of some more ideas today
NSBCraig
Wow your a bit of an ***** aren't you?
Simply as the answer is you need a different exhaust if you want it higher.
Look into some headers.
Hey maybe check out a marine exhaust manufacturer.
But there is no need for a raging attitude.
Do some research before you ask the same question over, we get it you didn't find some half *****ed way to jury rig your boat up in a way that would not work and you haven't put forth any effort to actually attempt to solve it for yourself.
Try google.
slasmith1
If it ain't broke fix it till it is. :D
NSBCraig
Yeah rig it till she blows!
weider1717
Try google.
ya bondo doesn't bring out the best in me...me and him can't stand each other so he goes around picking at my threads..
weider1717 said:
you located anywhere south east? if so and you got something to prove lets swap numbers and meet up.
I got no problem kicking a older mans azz.
I bet your're from up north tho u have that yankee attitude to ya.
Ayuh,.... No $h!t....:eek:
Btw,... My Address is in every 1 of My posts,.....:rolleyes:
NSBCraig
Oh, Good Times.
mh11
Uh, guys, remember this is supposed to be fun, isn't it?????????
That exhaust sounds great, why would you want it higher??
Just my opinion. You all have a great day!!!:rolleyes:
25thmustang
I think that would be a lot of work to simply move them up? You would have to patch the transom where the old exhaust went through, replumb the new, and then cut the transom for the new. Is it worth that effort for the sound?
H8tank
Isn't the exhaust out of the water when under way?
Not sure I understand why you want to go through the trouble?
Just ignore Boondo, OMC derangement syndrome. :)
a70eliminator
1000 bucks is a small price to pay for more decibles, just ask a Harley Rider lol. not much for power but the sound is where it's at, could this fit your description? Oh and believe me I'm no stranger to the sound of a well tuned way over advanced V-8 idling with open headers, I have a captains call ON MY CAR!
