optimax 115hp 2- stroke alarming at mid throttle
dieseldod
as long as i can remember this motor has alarmed at 50% throttle openings, i run it maxxed out all the time and it never misses a beat. starts and runs great going harbour speed or flat out, try to do a sensible cruising speed and it alarms and if if you idle back then straight onto throttle again the alarm resets
Texasmark
Agree. Water pump is dual functioning....at low speeds acts like a displacement pump....blades touch the walls of the eccentric chamber starting with a large volume and compressing to a small volume as the revolution completes, developing the water pressure.
At high speeds it acts as a centrifugal pump with the blades folding back (detailed in published data...forgot source), and with the incoming water pressure via the water inlet ports on the LU...shaped as they are, just like on a jet aircraft to scoop air, they scoop water, the pressure increases. By folding back, the water pressure is variable/soft, even though it's 3x idle pressure roughly, and nothing blows up like would happen in a hydraulic system with a displacement/reciprocal pump requiring an over pressure regulator to protect the system.....or something to that effect.
Your "ram water" at WOT, which is limited at 50% throttle setting is masking the worn impeller. (opinion)
dieseldod
thats the only thing I could think it was thanks guys , I will change the pump. I never have any issues with it but its when someone else is using it ,it always alarms. good stuff thanks to you all for the great input
dieseldod
flyingscott, is it an Evinrude only code reader? I have readers for all vw /vauxhall/ ford car based . I have old obd2 readers as well I can't use any of them to read I suppose? thanks again
