Optimax Annual service.. 220 hours
newo
HI i've got an mercury optimax 200 year 06.. has worked for 220 hours, going to give it an annual service is there something i should change after 200 hours for example impellor, plugs or something in particular...
Thanking you in advance for your help...
zzzzz
Re: Optimax Annual service.. 220 hours
pull lower unit and change gear oil,change water pump impeller,pull off prop and check for fishing line/grease propshaft,grease engine fittings,replace any inline fuel filters/water separator filter,check/change spark plugs(some of the Opti plugs are $20 each !)...overall visual inspection of hoses/belts:cool:
