Optimax Compression
Jobu67
Hello, I am going to look at a 2002 Merc Optimax 225 and was wondering what good compression numbers should be.
Thanks,
Joe
jerryjerry05
Re: Optimax Compression
The compression should be all about the same.Say about 110# on all 6.Each cylinder can be 5-10# different than the next. So if all are 110# and one is 75# There is trouble.Your tester might read different than mine.So you might get a different reading.A big variance will show trouble.J
Jobu67
Thank you Jerry. I will be heading up at the end of April to check it out and will let you know what I find.
Joe
