Optimax wire connector
boatguya1
Ser 1B364547 90HP opti.
I need the connector that plugs into the ignition coil and can't locate it on the EPC. I'll be in Hayward for optimax class with Jim Fry on Mon so can ask him then. Anyone know where merc hides the part number or have a source?
Thanks,
James
Fun Times
Re: Optimax wire connector
Here's a used harness for $149.00, Part # 896264T01. Spare parts.;)
Mercury Wiring Harness 896264T01 2006 90HP Optimax 90ELPTO | eBay
Did you happen to see item number 39 under electrical components? Part number 822447T01.
Merc has a list for Weather Caps, Plugs and Terminators, Here's a link with photos that maybe you could match up.
Weather Caps, Plugs and Terminators - Performance Product Technologies
898116 - Electrical Components and Harnesses,
https://webapps.brunswick.com/liter...DFI&umlModelYear=2006&catnbr=898116&isisFlag= <<< For future reference, hit the drop down menu in the link.;)
If i recall correctly, Jim has a few sources of how to find & order the plugs for the wiring harnesses.;) Good luck and stay out of trouble while in Hayward.:fencing:
boatguya1
Thanks for the info,
James
boatguya1
I always enjoy the conversations between Jim and the classes. Sometimes I leave feeling like I've been to see a "motivational" type seminar speaker. He's a cool guy and a seriously good person from what I've seen. I'm guessing that the current political climate will yeild some good conversation although I have a feeling that most of us will be in agreement.
Once again thanks for your time, as usual, now I feel obligated to spend some time answering a question or two on the sterndrive forums.
James
boatguya1
Thanks,
James
84-854839T02 for the connector,inspect harness, replace all coils, and possible PCM damage seems to be the answer. I didn't even have to ask, it was part of the class.
Fun Times
It appears mercury has seen this a few time in the past.
Do you think Jim knows of a different list of how to find other OEM connector types for the the wiring harness? Also keep in mind, i believe there may be an "merc" wiring harness conector "pin extraction" tool kit available as well. Not sure of a part number if in existence, but should be pricey if they have one, $$$.:numbness:
boatguya1
There is a service bulletin for merc OB and another for merc SD with all "their" connectors. The merc tool for pin extraction is mentioned being plastic, it appears the old omc tools will do the job just fine. The replacement connector for my application comes with wire and bullet conns.
