Orange and pink wire
baja89
I have a 1989 baja 280 and have a loose pink and orange wire dangling in the cuddy where the fridge usually is, but no longer there. Also has no horns. Would this be one of those?
Ayuh,..... Welcome Aboard,.... A test light will tell you if they're powered or not,....
mike_i
Ensign
connect a voltmeter to the wire and honk the horn and let us know what happens.
dubs283
Like holding the dvm leads to a fuse and reading 56k ohms?
Um, that's your resistance
Oh yeah, through one arm, chest, and your other arm
Pink is fuel sender
Orange is alternator or post circuit breaker battery feed
You sure it's not purple? Then it would be wiper leads. Purple for power, orange for park, and a black wire
baja89
The boat is missing the horns.. would that be test light to ground? Not much of a electrical guru.
04fxdwgi25
Wire certainly has 2 ends to it.
Look under the dash to see if same colored wire is connected to a switch / piece of equipment or breaker. Then read what the breaker/switch is for. Problem solved.
