ore locks
tav
how hard is it to put ore locks on a boat , i hope this isn't a dumb question.
triumphrick
Re: ore locks
This topic may have to go under " inflatables, ribs and canoes"...:D
Bob_VT
Re: ore locks
First welcome to iboats!!
Second no question is dumb!
Third I think you mean Oar Locks :D
Very easy to install ..... tape measure, drill, common sense and patience. Depending on the design of the boat and boat rail you may have to fabricate a plate to bear the load..... all sold here! http://www.iboats.com/Boat_Parts_Accessories/dm/keywords.oar locks
mthieme
Re: ore locks
Ditto on the backing plate.
Positioning in relation to where you are sitting is important. The length of the oars will also come into play here. You want to be comfortable when rowing.
tav1
Re: ore locks
well looking at a 14' starcraft utility and i don't think it has ore locks on it if i'm to get the boat i would want to put some on just in case i need to row to shore , and run out of juice with my troller and it did happen 1 time that because i didn't bring them. by the way where do you get a backing plate if you need one ,in the same site?
reelfishin
Re: ore locks
What model Starcraft? I have two Starcraft 14' boats, both came with oar lock mounts. All I needed was a good set of oars.
Your oars will be in the 6.5 to 7.5" range on most boats that size.
I prefer the old school style pin and horn style pivot, and good old fashioned wood oars, but that's what I got used to years ago. I have both a gas and electric motor for mine, but often leave them home and just use the oars in most small ponds. It's good exercise and can be very relaxing.
I have 6.5' plain wood oars, I sand and re coat them each year with fresh urethane, and they've lasted over 15 years so far. I use them on both my 14 and 12' boats. Both have about a 53" beam width.
tav1
Re: ore locks
i trying to get over there to look at the boat but from the pics he gave me and matching it up to online pics it looks like a 14'S (seafarer) ,but the year is a 1972 not sure on the beam.
woosterken
Re: ore locks
I would think a pair of hand cuffs would keep her in
woosterken
Tinman57
Re: ore locks
Oars are great to have on any small boat, not only as emergency propulsion, but for silent trolling, exercise, and for exploring shallow water.
My 22 foot power dory has oarlocks and a set of 10 foot oars, and it weighs 2700 pounds loaded.
