Original 1998 OMC 176615 Stainless Steel Boat Propeller- can it be rehubbed?
OutrageIII
Any input welcomed; prop in perfect condition just now starting to slip on planeing
tried to remove OMC inner hub but it will not budge.
boat 1999 outrage III
Motor 1998 Evinrude 115HP Fitch
thanks
OutrageIII
Thanks Racerone
I didn’t know if the 1998 OMC SST prop had a replaceable inner hub; the service manual shows a hub in the parts break out illustration but that part is no longer available. I can press it out (likely) but the question remains if a replacement aftermarket hub can be located. I’ll look into this further before purchasing a new replacement prop from iboat.
Cheers
call a reputable propeller shop. even a volvo prop (with a permanently bonded hub) can be rehubed.
OutrageIII
Thanks Scott
i didn’t know that. I’m in touch with a prop shop in Gainesville Florida that looks good for swapping out the hub.
Cheers
Chris
if that doesnt work, General Propeller in Bradenton is probably the best prop shop this side of the mississippi
OutrageIII
Nothing from Gainesville today; I believe I’ll try your recommendation Scott. I’ll update the post with my findings.
Thanks again
cheers
Chris
