Original Equipment Prop Size Question...
Jakkal99
I have a 4.3L Volvo Penta with an SX drive... 205 HP... Mounted on a 20' Cobia bowrider... My question is if anyone can tell me what the original equipment prop size was? I bought the boat last season, and have only taken it out once. It currently has a new prop installed by the previous owner that's a 14.8 x 17 aluminum style. We plan to pull a tube for the kids and I need to buy a back-up prop to keep onboard. I need a starting point to determine if the previous owner already reduced the pitch to 17 to accomodate for the towing/skiing or if not, do I need to drop it further to get more response from the prop? Any help you can give this "rookie" would be great! Thanks!
Re: Original Equipment Prop Size Question...
Ayuh,...
There's Nothing standard about propping a boat,...
Go Run it,+ come back with the Info, Required....
It's listed in the "Read This First" sticky at the top of the forum....
steelespike
To be specific get us the present prop size,max rpm and speed,also the rated max rpm.Not an expert but I don't think thats the original prop.
