out drive goes down not up
Rich Novak
1972 225 electric shift sterndrive omc.
The o/ d goes down, up only if you help lift it up.
Battery test 12.8 v new motor and solonid, new switch. Clutch oil good no water.
Thanks, Rich
What should I do.
wrench 3
I will assume that dpratt's post is in the wrong place and that one of the moderator will move it.
Rich: Is the spring OK in the hammer blow coupling.
Rich Novak
I believe it is OK I had the coupling out when I replaced the motor it is not broken and holds the coupling together .I have checked everything sho rt of chsnging the clutch pack oil, I checked it no water.
Thanks , Rich
southkogs
Does your outdrive go up and down easily by hand? Just wondering if your outdrive is binding up on the trunions at all.
Rich Novak
Goes down easily, will go up if someone helps it while I operate the switch.trunnions plenty of grease.
Thanks, Rich
wrench 3
Check the voltage at the connector closest to the tilt motor. In case your getting a voltage drop somewhere. If that's OK it sounds like your going to have to pull the clutch housing apart. Maybe a bad thrust bearing on the worm shaft.
Rich Novak
OK, thanks I will check out the clutch
Boomyal
Did I read that you replaced the tilt motor? Some, and I don't know how to identify them, just do not develop the proper torque required to raise the outdrive. They are usually the cheaper ones. I would get your hands on a manual and do a torque test, per the manual, on the motor.
Rich Novak
I heard that also, I asked a marine parts MaN that question, he said it doesn't matter what the cost is the torque should be the same
Boomyal
Maybe they should be but THEY ARE NOT!....and you will not know it until you do a torque test, as per the manual. All other indications are that your OD moves freely and you do not have a current problem. Also the fact that your drive does not slip in the clutches is another indicator that it is a tilt motor with insufficient torque to raise the drive.
wrench 3
My manual says to put a blade type screwdriver bit onto a torque wrench, insert it into the slot in the end of the motor shaft and power up the motor. The first time I tried that it broke the end of the shaft. So since then I've put a small hose clamp around the shaft first.
boobie
I'll go along with a voltage drop some where. Get a volt meter and start testing.
Rich Novak
OK.
I removed the motor and worm gear.
The motor had twisted the shaft to the point of twisting the slot to the breaking point.
I ordered a new shaft and gasket set will test the torque of motor.
I don't know why it twisted it this time it has been a problem all along, and I have had the motor out b/4 to check the hammer blow witch by the way is still good.
Thanks, Rich
